AZRockRunner said:
Also, check the lower hose and make sure it is not collapsing. Most of the aftermarket ones dont have the spring in them and collapse under heat and pressure. Getting one for a 91 from the dealer fits perfect and prevents that problem.
Yes, but he is overheating when idling. RKbonds, I assume you are able to cruise on the highway without any problems? The higher RPMs when on the highway (or doing anything but idling) are the only times there is a slight chance your lower hose is collapsing. Just gun the throttle with the hood open and look at the hose. I had a non-spring hose in there for awhile and even with the rpms up to 4000 or so, the hose squeezed itself an almost unnoticeable amount, and this was with a 14 year old clogged as hell radiator
(which I subsequently replaced :spin1: ). I did eventually put the dealership one back on with a spring after I got my new radiator, but not before I had gone for a long, strenuous drive and I had no problems.
So, bottom line, I highly doubt your hose is your problem, BUT the dealership hoses are of a higher quality and can give peace of mind.
Now, onwards. As stated above, if you aren't overheating at high speeds, your radiator is almost certainly not the problem, although it is not unheard of for one to go bad in a very short period of time, especially if the block has a lot of junk in it when the switch is made. This leaves 2, or I guess more like 3 options.
#1: Water pump: I know you said it is new, but trust me, I had a period where I went through more water pumps in less time than I thought was physically possible. If the impellers are eroded or damaged (especially if only water and no antifreeze was used for awhile), they won't do much when idling but when moving fast enough may provide enough flow when not idling.
#2 (and 3): Airflow. I know this sounds obvious, but make sure the path of air from outside the grille to through the radiator is completely unobstructed. Get a fin comb or icepick or tiny screwdriver and straighten condenser fins, radiator fins, degrease everything and hose out, clean crap out from on the radiator supports, etc. I did that once a few years ago and it made a huge difference. If your mech. fan is locked and your e-fan is always on, I'm at a bit of a loss there, because you can't get much more airflow than that, at least with the stock fans. But the huge majority of slow moving overheating problems have to do with a lack of airflow over the radiator.
I'm in the process of getting ready for putting in a fan from a Lincoln Mark VIII to replace the mech fan. My clutch is bad again and locking up the blades worries me when those blades aren't rated for high rpms. Cheap clutches are a crap shoot, and good ones or ones from the dealer are well over $100. I know many have gone with the elec fan approach to solve low speed problems, but when I get my fan I plan on giving a full write up/pics for anyone who is interested.
The right thermostat will keep the flow in check, like others have said.
