Overhead console
wantedu2cme
Colorado
i have a 99 cherokee sport and currently do not have a overhead console and im wanting to purchase one and also wondering if the wiring for the console is already there or do i need to purchase the harness and ive also heard about a bracket and somthing about a temp sensor please inform me
you will need to pick up the harness...you'll need the bracket too to mount it on the roof. the temp sensor wiring is already in your car, you just need the sensor itself (which is located on the back of the front bumper). you can get all of this at a junkyard and usually find deals. for the wiring, make sure you get the same harness as your year xj or else you have to cut and splice, but if you get the same year it's plug and play.
Certain year Dodge Caravan/Grand Caravan consoles will fit as well - I believe there may be a signal issue with all the functions though if I remember correctly. I know there was quite an extensive report on these over at www.ilovejeeps.com about a year ago
Thats correct. The computers are diffrent,so the info will not be correct or wont work at all in some cases.
