Ok, just reporting back. In a nutshell:
1) replaced waterpump (was leaking) + t-stat (for no particular reason other than that it is convenient to do when the w-pump is replaced).
2) after that engine temps too low (160 highway, 170 city with 60-65 ambient outside temps), symptoms resemble t-stat malfunction.
3) replace t-stat with Mr Gasket high-performance t-stat (original replacement was standard stant); I always use 195 degrees t-stats.
4) temps again low (same as before)-> concluded: it's not t-stat (just replaced).
5) post
, re-burp, change temp-sensor, check fan-clutch, think deep....
6) ran out of fantastic scenario's and back to t-stat, must be t-stat (although statistically mysterious)
7) Today replace t-stat with dealer OEM t-stat......voila, temps are great nice around the 200, just where they should be!!
I'm clueless how I could have had two malfunctioning t-stats in a row but its seems that way after all. I did test that MrGasket in a pot of water on the stove and it seems to work reasonable, but for some reason it performed poorly in the Heep. Anyway, this is just to give you guys a heads up on progress. If you have any thoughts on the t-stat mystery let me know!
Tim
