Correct with filter change.Blaine B. said:If you have the 4.0 6 quarts is the recommended.
Prowler said:Yes I changed the filter too. I also replaced my air filter with a KN but it seems to not fit perfect. Should I take it back? it's like it is BARELY to small.
OK then I wont worry about it. I will just pop it open every once in awhile make sure it hasn't fallen.XJPhoenix said:I had the K&N filter for my old 1991 XJ, and it had the same problem. I don't think exchanging it will help; FWIW when I sold the XJ the filter fit perfectly into my brother's TJ airbox. I think it's 'one size fits all 4.0's mentality.
I also but BRX silicone hoses on.
Prowler said:OK then I wont worry about it. I will just pop it open every once in awhile make sure it hasn't fallen.
and cool on the 6. Thanks all!
