98JeepXJ
- Johnstown PA
Well, I FINALLY got around to sending in the samples from the oil change I did clear back in October and the one I just did a few weeks ago. And...it looks like I have to do a head gasket pretty soon. :swear:
Blackstone and I have been watching my sodium and potassium numbers ever since I started sending in samples last spring, since the numbers were higher than normal. Since sodium and potassium are a sign of antifreeze in the oil, they bear close watching. The sodium and potassium numbers had been staying steady through the first few reports I got. Well, on the sample I took in October, the sodium and potassium content skyrocketed; this was partially due to the longer than normal change interval (6k vs. 5k) that I ran for that change that allowed more antifreeze to contaminate that oil.(I ran a longer change interval due to the fact that I was doing a significant amount of highway driving, and felt the oil could go longer) It also is a was a sign that the leak is getting worse.
On the sample that I took a few weeks ago, I actually ended up running a slightly shorter change interval than normal. This was due to the fact that it had seen some extensive idling, and again I felt it was due for a change. For this sample, the sodium and potassium numbers came back down quite a bit, but were still much above normal.
The October report:
Make: Jeep
Model: 4.0L Inline 6 cyl.
Fuel type: Gasoline
Oil use interval: 6,123 miles
Oil type and grade: Mobil1 15W50
Make-up oil added: 0.5 qt.
CHAD: We don't have any problem with the miles you ran on the oil, but we are concerned about the higher potassium and sodium, which point to antifreeze in the oil at about 0.64%. We have been seeing the sodium right along, but now we can confirm the problem. At this level, the antifreeze will destroy your bearings, and you can see the lead increase. Bearings are the only source for lead in this type of engine. You need to get your cooling system pressure checked. If you continue to operate this engine as is, you will lose it.
Element: My#/Universal average #
Aluminum: 2/4
Chromium: 1/1
Iron: 27/28
Copper: 4/5
Lead: 12/2
Tin: 0/1
Molybdenum: 61/35
Nickel: 1/1
Manganese: 0/1
Silver: 0/0
Titanium: 0/0
Potassium: 11/2
Boron: 42/42
Silicon: 17/12
Sodium: 321/8
Calcium: 2098/2022
Magnesium: 13/260
Phosphorus: 635/767
Zinc: 645/929
Barium: 0/0
Oil Properties
Property: Values should be/values tested were
Viscosity: 78-95/62.3
Flashpoint: >380/375
Fuel%: <1.0/<0.5
Antifreeze%: 0/0.64
Water%: 0/0
Insolubles%: <0.6/0.5
January report:
Make: Jeep
Fuel type: Gasoline
Oil use interval: 4,711
Oil type and grade: Mobil1 10W30
Make up oil added: 0 qt.
CHAD: The shorter oil use interval has lessened the problem of the contaminant in the oil, though the problem still exists. Normal lead (bearings) for this sample would be 2ppm. Your lead read at 4 times that. The contamination level this time was 0.19%. You probably have a minor cooant seep at the head gasket. It would not be that difficult to fix it, or expensive to have it fixed. If you need to drive this one as is, suggest using 3,000 mile oil use intervals and sample the oil at each change. We can tell you if the bearings are really getting into trouble.
Aluminum: 2/4
Chromium: 1/1
Iron: 13/28
Copper: 3/5
Lead: 8/2
Tin: 0/1
Molybdenum: 57/35
Nickel: 1/1
Manganese: 0/1
Silver: 0/0
Titanium: 0/0
Potassium: 6/2
Boron: 62/42
Silicon: 13/12
Sodium: 95/8
Calcium: 2002/2022
Magnesium: 10/260
Phosphorus: 782/767
Zinc: 848/929
Barium: 0/0
Oil Properties
Viscosity: 59-68/89.1
Flashpoint: >365/410
Fuel%: <1.0/<0.5
Antifreeze%: 0/0.19
Water%: 0/0
Insolubles%: <0.6/0.4
Any thoughts, questions....
Chad
The October report:
Make: Jeep
Fuel type: Gasoline
Aluminum: 2/4
Chromium: 1/1
Iron: 27/28
Copper: 4/5
Lead: 12/2
Tin: 0/1
Molybdenum: 61/35
Nickel: 1/1
Manganese: 0/1
Silver: 0/0
Titanium: 0/0
Potassium: 11/2
Boron: 42/42
Silicon: 17/12
Sodium: 321/8
Calcium: 2098/2022
Magnesium: 13/260
Phosphorus: 635/767
Zinc: 645/929
Barium: 0/0
Oil Properties
Fuel%: <1.0/<0.5
Antifreeze%: 0/0.64
Water%: 0/0
January report:
Make: Jeep
Fuel type: Gasoline
Aluminum: 2/4
Chromium: 1/1
Iron: 13/28
Copper: 3/5
Lead: 8/2
Tin: 0/1
Molybdenum: 57/35
Nickel: 1/1
Manganese: 0/1
Silver: 0/0
Titanium: 0/0
Potassium: 6/2
Boron: 62/42
Silicon: 13/12
Sodium: 95/8
Calcium: 2002/2022
Magnesium: 10/260
Phosphorus: 782/767
Zinc: 848/929
Barium: 0/0
Oil Properties
Fuel%: <1.0/<0.5
Antifreeze%: 0/0.19
Water%: 0/0
Chad
