Matthew Currie
NAXJA Member #760
- Vermont, land of big clay
Just adding to the above: air cooled engines are a different thing. VW and Porsche aircooled engines are, in a sense, oil cooled too. As far as I know, ALL air cooled VW's and Porsches had an oil cooler, built into the air passages. You won't see it but it's there, and was part of old Ferdinand's original design back in 1939 or whenever. It was the bane of the old upright fan VW engines, because the cooler obstructed air flow to #3 cylinder, causing that one to run hotter and burn valves. But that doesn't necessarily mean you need an oil cooler on your cast iron, water cooled, front mounted Jeep engine. An air cooled engine is always one small step away from thermal disaster.
My old Mercedes diesels have oil coolers as well, as befits the heavily loaded bearings of a diesel. Oil does have a significant role in cooling bearings, so it's a good thing to keep it from overheating. However, those coolers also have a thermostat to help speed up cold weather heating. A well designed cooler will undoubtedly help keep bearing temperatures from going too high if there is a danger of that, but will do little else, and will have almost no effect on overall engine temps unless there is already a critical problem with oil temperature. It's no solution if the problem is really in the cooling system.
An oil cooler in a Jeep that does heavy towing and offroading seems like a pretty good idea, but if you live in a temperate climate, I would not put one in unless it has a thermostat, or can be switched out of the circuit in cold weather.
