5-90
- Hammerspace
dennisgrimm said:5-90: From working on vw's I have seen both solid lifter and hydraulic lifter heads. They don't look a lot different size wise to me. The hydraulic lifters don't (read: shouldn't) need any maintenance.
Not "larger" in diameter - you can make a metal slug that will replace a hydraulic lifter (which is all a solid lifter really is.) However, you do have to have a bit more length in a hydraulic lifter than you do in a mechanical lifter - to accommodate the "hydraulic" part. A mechanical bucket follower can be a simple stamped bucket with a recess to accept a shim ("mechanical lash adjustment") - while a hydraulic follower/lifter needs to be (probably) at least a half-inch long to have room to pump up and to move oil.
I'm not trying to shoot down your idea - or belittle your experience - at all! I'm just bringing to mind something that will need to be thought about for something like this. I'm thinking it will be rather easier to have an overhead cam with rockers (with or without a ratio involved - anywhere from 1.0:1.0 to 2.0:1.0) and make for a bit shorter package than having the camshaft actuate the valves directly - and I know I'd sooner have a single overhead camshaft (fewer moving parts) than a double - even though you can get more valve curtain area and more "area under the curve" for engine breathing with a double and three or four valves per cylinder (the DOHC/multi-valve setup tends to shine at higher RPM, which isn't what we're interested in here. Low-RPM would probably respond to a more aggressive lobe profile, opening the valves sooner, and reliability would be served by having fewer moving parts (at least, IMO.)
If we're going to talk about redesigned heads, I'd really like to see a cross-draft head design using Coates Spherical Rotary Valves - significantly reducing moving parts, lubrication demands, eliminating valve float, and all that sort of thing (plus making for a shorter package than an OHC and nearly eliminating valve "hot spots" like you get with poppet valves... Look them up.)
