oddly optioned xj's
i just picked up a dark blue with red pinstriping 84 cherokee pioneer 2door, 4cyl, 5spd, 4x4 with 4.56 gears, limited slip rear axle, disconnect front axle with cv joints, rear wiper, am/fm radio, air conditioning, stock towhitch, dark blue interior with lowback front seats, digital clock, aluminum turbine wheels, and no center armrest console. don't know how rare that is, but i think it's a pretty neat little ride, especially for $200
Pics?
Hell, I'd pay that for just the front axle. I say you got a good deal.
x2 on the pics.
One of my xj's is a 2 door 98 4-cyl 5 speed 2wd, Its an SE with crank windows and has power mirrors also. I though that was weird too.
I'll throw in my opinion about POWER MIRRORS on late Cherokees.
'97+ have one piece side windows (no split to fit a vent window), the bigger window may have taken up the space through the door edge used for the manual mirror mechanism.
Mike
Mike
Doesn't seem to have taken it up in my case, the small triangular plastic panel that covers the spot the mounting bolts come through is where the manual mirror control was located. I generally didn't use the manual controls though because they didn't give me enough range of motion from age/corrosion, I usually stick my hand out the window and push the mirror itself.
That's where I put the late model tweeters. Takes up the space where the manual remote adjusters were in my '92.
http://naxja.org/forum/showthread.php?t=1044047
there's the link to my 'new xj' thread. there's a couple pics there.
i forgot to mention the strange gauge combo mine has....
it has the gas gauge where the tach should go, and an AMC logo where the gas gauge should go, and the voltmeter, oil pressure, and temp gauges are all where they live on most of these style gauge clusters that don't have idiot lights. it's the only one i've seen like this, anyway....
Here is my 89 4d 4.0l auto np 242.
BodyStyle: XJJP74
Color 1: PWB - PEARL WHITE
2: QWBS - PEARL WHITE
Options Descriptions
*Q7: TRIM STYLE Q7 - CLOTH BUCKET L/BK
-SA : *** DESCRIPTION NOT AVAILABLE ***
ADH : HEAVY DUTY ELECTRICAL PACKAGE
ADL : PACKAGE - 4X4 PROTECTION
AHT : HEAVY DUTY TRAILER TOW PKG
ALR : U.S. EASY ORDER PACKAGE JR'
APAS: MONOTONE PAINT PACKAGE - I
ARC : PREMIUM SPEAKER PACKAGE
AWHA: POWER WINDOWS & POWER LOCK GROUP
BA1P : 100 AMP ALTERNATOR
BCYP : BATTERY, 58-475 CC
BGAS : POWER DISC BRAKES - FRT/DRUM RR
BJAS : STD DUTY FRT DISC BRAKES
BKPS : 10 X 2 1/2 REAR BRAKE
CACP : BUCKET SEAT - LOW BACK
CDBS : RECLINING TYPE SEATS
CKBS : CARPETS - CLASS II LONG PILE 13-16 OZ
CKNP : CARGO TIE DOWN LOOPS
CKVS : SKID STRI PS :: CARGO_ FLOOR & -RR• ST BK
CLES : ACCESSORY FLOOR MAT - FRONT & REAR
CSAS : SP~E TIRE COVER
CSCS : TONNEAU COVER
CSRS : INTERIOR ASSIST HANDLE
CUFS : FULL LENGTH FRONT CONSOLE
DGB : STD DUTY 4 SPD AUTO TRANS
DGSS: 4SPD AUTO TRANS - AISIN WARNER
DHAS : LOCK-UP TORQUE CONVERTER
DHP :TRANSFER CASE 242 - SELECT TRACK
DHSS :AUTOMATIC TRANSMISSION - FLOOR SHIFT
DJHS: 2500# FRONT AXLE -DANA
DMDS: 3.5 AXLE RATIO
DRMP : SPICER 35C MODIFIED- RR AXLE
DSA : LIMITED SLIP DIFFERENTIAL
EAAC : ALL ENGINES
EAFC : ALL FUEL INJECTED ENGINES-GAS
E;lXB : ENGINE - 4.0L 16 MPI GAS
GACS : ALL WINDOWS - TINTED GLASS
GBBS : WINDSHIELD GLASS - TINTED
GCBS : FRONT DOOR GLASS - TINTED
GECS : GLASS - PIVOT VENT
GEDS : QUARTER WINDOW TINTED - FIXED
GFAS : ELECTRIC HEATED REAR WINDOW
GNAS : INSIDE RR VIEW MIRROR
GNBS : SUN VISOR - MIRROR - ILLUMINATED - RT
GRBP : LEFT-O/S MIRROR-RMTE-CHRM-TYPE ~I
GSBP : RIGHT-O/S MIRROR-REMOTE-CHRM
GXMP : KEYLESS ENTRY -AMC
HAAA : AIR CONDITIONING - FRONT
HGAS : HOOD INSULATION
JAAS : INSTRUMENT PANEL - TYPE 1
JAYS : ANALOG CLUSTER, RALLYE W/TACH -AMC
JBES : BEZEL-I/PANEL CLUSTER - GUNMETAL
JCAS : SPEEDOMETER - 85 MILE PRIMARY
JGBS : CLOCK - ELECTRONIC DIGITAL -AMC
JHAS : WINDSHIELD WIPERS - DELUXE
JHBS : REAR WIPER/WASHER
JJAS : CIGAR LIGHTER
JKBS : HOOD RELEASE - INST PNL MOUNTED
JPAP : POWER WINDOWS
JPBP : POWER DOOR LOCKS
KKES : *** DESCRIPTION NOT AVAILABLE ***
K3SS : *** DESCRIPTION NOT AVAILABLE ***
LAFS : WARNING BUZZER - KEY IN IGN/SEAT BELT
LAJS : WARNING BUZZER - HEADLAMPS ON
LBBS : COURTESY LAMPS (BELOW PANEL)
LBCS : GLOVE BOX LAMP
LBDS : ASH RECEIVER LAMP
LBES : LIGHT - CIGAR LIGHTER
LCDS : MAP/DOME READING LAMP (B-PILLAR ON NS)
LDBS : LIGHT, UNDERHOOD REEL TYPE W/21 FT CORD
LHDS : HEADLAMP ON TIME DELAY
LMAS : HALOGEN HEADLAMPS
LNJA : DUAL ROAD LAMPS-FOG
MB3S : FRONT BUMPER - BRIGHT/ARGENT
MB7S : REAR BUMPER - BRIGHT/ARGENT
MCAS : FRONT BUMPER GUARDS
MCBS : REAR BUMPER GUARDS
MDAP : FRT LICENSE PLATE ATTACH REQUIRED
MFMS : GRILLE APPEARANCE-BLK/BRT
MHBS : WINDSHIELD MLDG - BRIGHT
MMCS : DOOR & QTR UPR FRAME MLDGS
MMGS : BELT MOLDINGS - PAINTED
MMJS : DRIP TROUGH MLDG - TYPE I
MMPS : MOLDING - DOOR EDGE GUARDS
MTAS : BACKLIGHT MLDG
MWAS : LUGGAGE RACK - ROOF
NAE : EMISS CONTROL TESTING & LABEL
NBAS : LIGHT DUTY CYCLE
NBKS : WITH EVAP CONTROL SYSTEM
NFAS : TANK-20 GAL FUEL
NHBP : HVY. DTY/AUX TRANS OIL COOLER
NHMA : AUTO SPEED CONTROL
NMCP : MAX ENGINE COOLING
RAAC: ALL RADIO EQUIPPED VEHICHLES
RAFA : RAIDO AM/FM ETR STEREO W/CASS L/DNR -AMC
RCGP: STEREO - SIX SPEAKER SYSTEM
RDCP : POWER ANTENNA
SBAS : POWER STEERING
SCGS : LEATHER STRG WHEEL - EURO/SPORT TYPE
SFAS : STANDARD DUTY SHOCKS/STRUTS FRT.
SGAS: STANDARD DUTY SCHOCKS - RR.
SUA : TILT STEERING COLUMN
TAAC : ALL TIRES
TAEP : MUD & SNOW TREAD
TBB : CONVENTIONAL SPARE TIRE
TBLS : TIRE CARRIER - INSIDE
TRN : P225/75 R15 OWL TIRE
WJN : 15x7 5 SPOKE ALUMINUM WHEEL
XEEP : SKID PLT-F/TANK PROTECTOR
XEFP : SKID PLT- TRANS CASE
XEUP : SKID PLATE - FRONT SUSPENSION
YGBA : WINTER FUEL ADDITIVE
how do you get this info?
The one I had in my '85 which was a 5 speed 2 door with the V-6 just like yours was set up:
upper left...temp guage
lower left...AMC logo
Center left...fuel
Center right...speed
upper right...oil pressure
lower right...battery voltage
Isn't this what you have?
You want one? I got one....come get it....shows about 133,000 or so. Worked perfectly when I pulled it out of the Jeep.
I'm in Brentwood.
My dad has a 99 WITH Cruise, manual locks and windows NO tilt
My buddy also has a 99 With tilt, power doors and locks, and NO CRUISE. Just weird that both lack something very standard.
My 87 Pioneer had that gauge setup. I'm not sure whether it was a Pioneer feature or bundled with some other option. That Pioneer was an odd one, with no AC, no power anything, but with cruise, tilt wheel, opening vent windows, interior light options including mirrors, footwells and map lights, and a few other things, so I never quite figured out what features came with which packages.
By the way, if you've not run low on gas yet, don't be surprised when the AMC logo turns into a low gas light.
yeah, i haven't gone that low on fuel yet, but i have seen the outline of a gas pump there. not sure if mine will even work, but that is a neat little attention to detail thing that you didn't see on the chryco jeeps
