scorpio_vette
- Milwaukee Wisconsin
i just had this thought.
in a normally functioning a/c system, doesn't the clutch cycle on/off like every 10 or 20 seconds???
so if you use the a/c compressor for onboard air and end up doing some trail repair using air tools with a small tank (i have a 7gallon tank at 90on/150off psi) that would obviously make it run longer.
does that have any bad effect on the a/c clutch or the compressor??? or is the 10 or 20second on/off cycle just because that's all a a/c system needs to stay cool and and pressurized???
