And Dex II, III was what the OEM fill was claimed to be, not synthetic, Mobil 1, ATF-4 or any other new fangled ATFs.
And your point is what?
LOL, I was wondering the same thing about your all badgering me to switch to ATF, LOL.
I am a bit of a renegade, snake oil expert, chemical engineer, chemical product formulator, and I am not much on following OEM specs when I know what I am doing, which in this case (choosing to use oil and not ATF in the Transfer case) I do.
....I am not much on following OEM specs when I know what I am doing, which in this case (choosing to use oil and not ATF in the Transfer case) I do.
The small pump isn't much for pulling thick fluids. If it was plash lubricated that would be different.
Said the guy that couldn't locate the fill plug.
It's 30mm iirc. Only reason I own a 30mm socket was because my old tcase in the 96 had the hex head instead of the huge allen socket.I found a nice image:
http://www.jeepkj.com/forum/showthread.php?t=30383
The $%#@&^%$ is almost 1-1/4, but not 1-1/4 and not 1-1/8, and all my large sockets are US, not metric, POS nuts! LOL, I used an adjustable, fits all wrench!
Turns out this 24 YO, NP242 has never had anything but motor oil in it. Looked like it had never been changed either!!! It was black, like well used diesel oil, and about the viscosity of gear oil that smelled like a sulfur plant. I put API SL grade 20W50 back in it.
We got it all together, and bolted back on the engine today!!!
FWIW, I drained a 242 that I just swapped into my '99XJ and it really looked like motor oil coming it. It was very dark and almost smelled like used motor oil. However, putting a shop light behind the dripping "oil" showed it did have a tint of red to it. Sounds like you might have just had a transfer case that was in dire need of fresh fluid.
