Harleyhector
- Nashua, NH
I agree. Its in great shape. Not bad for the money. Also, I agree on the S-10 leaf springs. Start there, get your self a used set from which ever source suits you best. Probably for around $100 I'd say. Install them and see how much lift you gain. After you have that measurement, lift the front accordingly. You will need the coils, at least the lower control arms, longer shocks, extended brake lines, an adjustable track bar or lowering bracket, and depending how high you go, I'd say a drop pitman arm. You can also get the pitman are out of a V8 Grand Cherokee ZJ. While you are sourcing out the ZJ, grab the tierod and all of thast type of stuff. You can find people parting them out on Craigslist.com and get the parts for next to nothing. If you gain any more then 3 inches total lift on the Jeep, Yes. grab the "transfer case" lowering kit. They are nothing more the steel bars or poly type pucks. It will help you keep your driveline angle in the rear at proper specs. It will reduce vibrations. A locker will help you in offroad conditions. It will give you traction to both wheels when under acceleration or constant speed. When you left off the gas to negotiate a turn, it will act as an "open" diff and create less wear on your tires and drive line. Its a great addition to any Jeep. I'd stick with 31in tires. that Jeep most likely has a Dana 35 rear axle. Not the strongest jeep offered. 31s should give your axle no problems. Lastly, I also agree to doing it yourself. These Jeeps are fairly simply to work on. Grab a repair manual, educate yourself by reading a lot of good info on this site and many others like it, and give it a shot. Don't be afraid to ask lots of questions. The only STUPID question is the question NOT asked. Do it right, learn some stuff and have fun!!! Good luck!!
