NON-XJ: Panasonic 47" HD TV $625
JohnJohn
Member #42
Austin, Texas
Panasonic 47" HD TV $625. I have service records. Works great with the Yamaha Receiver I am selling also.
* 47-inch widescreen projection television with 1080i/480p resolution; 43.7 x 48.7 x 24.6 inches (W x H x D)
* DVI-HDTV input; 2-tuner PIP with 8-bit PIP image processing, PIP scaling, and multiformat PIP (HDTV compatible)
* Progressive Cinema Scan (3:2 pulldown) provides faithful reproduction of film-based programs
* Motion-adaptive 3D-Y/C digital comb filter enhances resolution by removing blurred edges between colors and reducing dot crawl
* Digital velocity-modulated scanning improves the definition at picture edges
* Color: Silver and black
* Screen size: 47 inches
* TV type: Rear-projection
* HDTV capable: Yes
* Aspect ratio: 16:9
* CRTs: 7-inch
* Fine-pitch screen: Yes (0.52 mm)
* Speaker wattage per channel: 15
* Number of speakers: 2 (2-way each)
* Flash-memory port: No
* Includes radio: No
* Comb filter: Digital motion-adaptive 3D-Y/C
* Horizontal resolution: 850 lines
* Invar shadow mask: No
* Digital convergence: 165 points
* Dynamic convergence: 9 points
* Lens system: Digital HD 4-Element Hybrid, Tinted Red and Green
* First-surface mirror: Yes
* Screen - VVLL Brightness Uniformity: Yes
* Scan velocity modulation: Yes (selectable)
* Line doubling: Yes (progressive scan)
* 3:2 pulldown: Yes
* Noise reduction: Yes (Luminance YNR Video Noise Reduction)
* Video DAC: 10-bit, 60 MHz
* Apacon: No
* Includes DVD player: No
* Includes VCR: No
* Signal type: NTSC, decoded ATSC (720p/1080i)
* Protective screen guard: Yes
* Black-level expansion: Information not available
* Auto channel setup: Yes
* Channel labeling: Yes (presets only)
* Channel banner: Yes
* Input labeling: Yes (with presets)
* Input memory: Yes
* Input skip: Yes
* Closed captioning: Yes
* Mute: Yes
* Surfing: Rapid tune
* Picture enhancements: Horizontal/Vertical Edge Correction, wideband video amplifier, color matrix adjustment, Artificial Intelligence Picture, 8-bit PIP image processing, 10-bit A/D image processing, video picture memory
* Last-channel recall: Yes
* Channel search: Yes (3 channels)
* Favorite-channel scan: Yes
* Multilingual menu: Yes (English, Spanish, French)
* Parental control: Yes (V-Chip, channel lock, GameGuard)
* Picture-in-picture (PIP): Yes (2-tuner, split-screen with multi-format display and scalable size, .25 to .0625)
* Remote control: Lighted-disk (with SAP/DVS button)
* SAP: Yes
* Auto clock set: Information not available
* Sleep timer: Yes (and auto power on)
* Audio tone controls: Yes (bass/treble, BBE High Definition Sound)
* Audio balance: Yes
* Surround sound: Yes
* VGA/SVGA input: No
* Audio outputs: 2 stereo analog (left/right) RCA: 1 fixed-level, 1 variable-level
* Audio inputs: 5 stereo analog (left/right) RCA
* Video outputs: 1 (composite-video)
* Video inputs: 12
* Headphone jack: No
* Digital video input: 1 (DVI-HDTV)
* Component video: 2
* Composite video: 4
* S-video: 3
* RF: 2
* Monitor: No (includes 181-channel NTSC tuner)
* Color temperature control: Yes
* Front AV jacks: Yes
* Side AV jacks: No
* Sound leveler system: Yes (Artificial Intelligence Sound)
* Component linking: No
* Power supply: AC 120V, 60 Hz
* Power consumption: Information not available
* Energy Star compliant: Yes
* Item width: 43.7 inches
* Item height: 48.7 inches
* Item depth: 24.6 inches
* Item weight: 174 pounds
* Warranty: 1 year parts and labor
PM me
