- Hammertown, USA
Coo. Post back and let us know if the new seals fixes it or not.
markaboo929 said:what i have is a 95 housing 97 tj shafts.everything else is 88,knuckles,bearings,calipers,rotor,pads.
absolutely brilliant information regarding that seat.RobertF said:I have adjusted this with the axle fully assembled.
You leave the top ball joint tight. I don't know why they call it a ball joint, it's a shaft and bushing really. You can pull the shaft in and out of the outer housing of the upper "ball joint", it turns, but doesn't flop around like a real ball joint. I'd call it more of a "unit kingpin".
Now the bottom ball joint IS a ball joint.
With the axle on a jack stand, wheel off (I can't remember if you have to take the caliper and disk off or not, you'll be able to tell if you need to for clearance) loosen the bottom ball joint nut a couple of turns but don't take it off, drive the knuckle down to pop the stud out of the taper. The nut will stop the assembly from dropping too far and over extending the upper "ball joint".
Now remove the bottom nut and reach up inside the knuckle with the special "castle socket" to adjust the "split ring seat" to center your axle.
It's all upside down, you screw it up to lower the knuckle.
Do it in steps, adjust it a little, put the nut on and torque it, visually check the center of your axle in the outer tube end, if not centered keep repeating these steps untill it is.
If the "split ring seat" is protruding out of the knuckle to get your axle centered, it is distorted beyond use (usually over tightened, or rusted away) and must be replaced, it must be fully contained within the knuckle. You can get them through NAPA (for some reason listed under D44) or Specialty Products in Cololado (alignment parts)
Good luck, it may take a couple times, but there's satisfaction in a job done right!
