XJZ
- SF Bay Area
So here I go again....
Now I have no spark coming off the coil. Do other sensors keep the coil from doing it's thing? Just changed the CPS. Could it be the MAP sensor? TPS? What else would keep the coil from sparking?
OR.....it it just the coil itself? Is there a way to check it (don't have any meters, etc.) Jeep will check it for $100-seems rediculous. Also if it is the coil, is it best to replace it with the factory coil, or after market, I remember a post that sais you are probably better of with the stock coil and that there's little to no advantage with an after market such as the MSD, etc. Also are there better places than the dealership to purchase.
Any and all comments much appreciated.
TIA.
TIA.
