LI22limited
- patchogue
i have a 91 cherokee limited and one day while driving it coughed and shut off ..... tried to start it and nothing ... towed it to a buddys garage and started diagnosing it .. changed a long list of things
-cps changed twice
-plugs
-wires
-cap and rotor
-distributer/ old one had teeth worn and broken .. thought i nailed the problem there but no still no spark
had multiple skilled people time the motor and still to spark from the coil .. traced the wire back no breaks in the wire ...
checked every single fuse in the truck all good ..
checked compression it was very odd reading variations from 50 to 180 ..
so my mechanic said the crank could be messed up oil pump could be seized from the metal off the dist. sooo i swapped the motor ... got it all buttoned up new everything and still no ****ing spark im stumped the only thing i could think of it the ecu or the harness what do you guys think
-cps changed twice
-plugs
-wires
-cap and rotor
