I've got a 2001 XJ with the 4.0 and the FSM and the parts catalog. I can't find the part number for the oil pump drive to block gasket. After removing the cam sensor which is also called the oil pump drive, there is a gasket in the block that is removable on the exterior. It's just in front of the oil filter adapter. The procedures define on how to remove and replace the drive and say to remove and replace the gasket. It appears to be an ORing. Before I screw it up in removing it I want to make sure I can get a new one but no part number found in any search. Anybody know the part number?
