EVIL95XJ
- South Bend, IN
92 cherokee 4.0 auto
Here's the problem. Bought the wife a xj for a christmas present and while driving ihome I signaled to turn and the headlights cut off and both turn and high beam indicators lit up. I have sence changed the headlight switch with no luck. I have noticed now when u pull the signal arm to switch to high beams there is no click.
Could the dimmer switch on the column be causing my headlight problem?
Thanks, Paul
Thanks, Paul
