PoconoChris
- Poconos pennsylvania
2000 jeep xj....crank no start no injector pulse, "no bus" but has spark (sputters spraying carb and choke cleaner in throttle body)
- Cam and crank sensor check out at 5 volts.
-Have fuel pressure.
- replaced cam and crank sensor
-currently disconnected crank and cam sensor and turned ignition on with same no bus issue. No gauges move.
-ohmed out pcm on 30 and 28 for the ccd and got 120 ohm
-ohmed out ccd from the diagnostic port and got 60 ohm
-ccd + and - are 2.40 and 2.41 volts respectively.
-Disconnected tcm and no change with no bus
-checked EVERY FUSE
I'm out of ideas?
-checked EVERY FUSE
I'm out of ideas?
