spinaldex
- Oregon City, OR
Also, to make sure I'm addressing your specific requests from post #53:
Try using an Ohmmeter from pin cavity 4 then 5 at the DLC to chassis ground and see if you have continuity to G102.
- Yes. I performed this test in two ways. #1 - used a chassis ground near me. #2 - ran the multimeter all the way to G102 and to the pin cavity 4/5. Both failed. Then did the same two tests to E7 on C100 (which should be where one of the grounds from G102 goes) and it worked. Then I did the same to A1 (which my wiring schematic also says should go to G102) and it failed.
When checking for power at DLC Cav 16, did you try using the dash structure, or some other chassis structure, as the ground for your meter?
- D. All of the above. I even ran the ground from the multimeter all the way back to G102 for shi_s and giggles, and no dice. Then I used all the same grounds to E6 on C100, which I believe is the same power source intended to go to the headlamp switch which eventually is suppose to lead to DLC, and it worked. Which is why I believe there's something wrong in either the headlamp switch, or between the headlamp switch and the DLC.
