LittleAnthony88
- New York
mrbill3 said:I have a thought. Switch to decaf. Also we understand your frustration, but you will probably get more help by not being such an ass.
Now everyone has said it and I will say it again...re-bleed the brakes, only this time do it right.
1. Be sure the fluid res. is full.
2. Open the bleed screw and have someone step on the pedal(slowly).
3. Close the bleed valve.
4. Have the helper release the pedal(slowly).
5. Repeat steps 1 thru 4 until there is some pedal pressure and no air coming out.
6. Move on to the next wheel and start over.
Start at the farthest wheel from the MC and work your way to the closest wheel. If this does not solve the problem or it won't hold pressure you either have a small leak or a bad MC
I have done that 3 times over on your guys recomendations so i hope you understand my fustration now OK!!!!!!!!!!!
