grasseater
- Mostly hotels
This weekend I pulled my front and rear axles to have 4.56's installed and to swap in a D44. Got everything back together today, bled the brake system, and still no pressure in the pedal.
When the vehicle is turned off, you can pump the pedal up to get pressure. When it's started and running, no pressure builds up in the system & the pedal goes to the floor.
The 44 has all new drum brakes (12" vs. the 10" on the D35). I also put new pads on the front calipers.
Any ideas? The brakes worked fine as of Thursday night when I pulled the axles (and disconnected the brake lines).
