I am glad the pics show for you. I don't understand why some folks can see them and others not. I can't see them myself.
Those spacers came from Boostwerks. They were part of the Comp Mount package. I don't know if they will show as a separate item on the Boostwerks site, but if not I would contact Bryson and ask if he can sell you a set separately. And if he can't, I believe there are other companies who have them as a separate item.
That said, I would be inclined to try to avoid going with the spacers if possible. They lower your sway bar in the front. Unless you have another good reason to lower it (such as the Comp Mount) you are giving up ground clearance un-necessarily.
The first thing I would do is loosen up the mount bolts for the sway bar and try to simply shift it forward. The holes probably have some play that may get you enough clearance. Try that first and see how much of a difference it makes. If not enough, then consider elongating the holes in the sway bar mounting brackets. Maybe pick up a pair from the junkyard to play with.
Actually, now that I think through this, I think the first thing to do is evaluate the condition of your sway bar bushings. If they are too far worn it would be good to replace them first and then see what your clearances are and work from there.
Those steps won't cost you ground clearance and may save you from needing more parts. Certainly worth a try in my book.
