jeeperjohn
- Temecula, CA
Did you lube/replace the caliper pins? The pins can get gunked up with old grease and prevent the caliper from sliding properly and cause less contact of the brake pads on the rotors. If this is not the problem then the only thing that fits the symptoms you described is air in the system somewhere. It shouldn't have been able to get air in just by pushing the pistons back in but the symptoms point to that.
