DesertRatRon
- Apple Valley California
I cant seem to find a thread on installing an on board air setup with a bit more detail on what i need and how to plumb it any info is much appreciated
Are you plumbing off the A/C or buying a kit such as a Viar? I live in Apple Valley, Your more than welcome to come check mine out, It's plumbed off the A/C.
I finished my recently and been meaning to make a write up. Used a York 210 with a serp pulley from Ryder fleet products. Mounted on the pass side so I could retain their factory ac. I have a 7 gallon tank mounted in the rear and can fill a 35 from 0 psi to 30 in about a minute. Bracket attaches to the stock motor mount, block and power steering bracket. We added an extra idler pulley between the compressor and PS pump to ensure enough wrap. Uses a stock lbz duramax belt and all routing otherwise is stock.
