JVRacer04
- Houston TX
nhrocker said:Cool, sounds easy enough.
How did you trace that starter lead under the dash? I just want to make sure I get the right one. And do I need to run a 12V straight from a constant power source to the lighter, then replace the ground with the lead that goes to the starter relay? Or can I leave the power to the lighter as it is (only powered when the key is run position) and just replace the ground with the starter lead? Since the key would have to be in the run position anyway, wouldn't that work?
yep that will work just fine, and i never thought of it working that way until after i ran a constant 12v there... and i just cut wires until i found the right one... heh
