jimbosz07
- San Carlos/Redwood City
Ready for a story? Here goes… Over the summer I yanked my front axle and took it down to Rear End Specialties in Santa Clara to have it regeared. I brought them all the parts (Motive gears, a 3.73 and up carrier, and a master install kit with Timken bearing and National seals, all of it brand new). After the install, I brought it home and threw it back under my Jeep. Everything was perfectly fine until about 300 miles later. My axle seals started leaking out the sides. I drove it back down to them and they replaced the seals (they charged me too). When I went to drive away from their shop, I noticed a steady thunking noise coming from what I thought was the front end. I pulled back up and they said it was a burr in the ring gear, cracked it back open, and ground any possible burrs smooth. Nothing changed so they told me to just drive it and it would either rub something until it got polished and I’d notice it, or clearance itself (great advice!)
I just went back down there last week because I was sick of it. They jacked it up and ran it in 4 wheel drive, but were unable to replicate the noise. They told me my transfer case was shot and that was causing the noise. When I asked them to take responsibility and pay for a replacement they told me to go fly a kite. I was infuriated, but went out and found another transfer case and swapped it in over the weekend. Now I have a newer transfer case that is all fine and dandy but nothing changed.
Here’s the problem: while driving at slower speeds (under 30) you can hear/feel a steady thunk, thunk, thunk varying with tire speed. Above 30 mph and road noise (exhaust, tire howl, etc) makes it impossible to hear. It makes the noise with or without a front driveshaft in and it is definitely easier to hear when the windows are up. The noise happens on both drive and coast. Yesterday I jacked up the rear and ran it in the air in RWD only. I was unable to replicate the noise. Using a broom handle as a stethoscope, I listened to my transmission, transfer case, and axle, and they all sounded fine.
I’m kinda stumped here guys. Any ideas?
