so i'm a poor college student so i figured i'd try to just change the O rings on the leaky injectors first b4 biting the bullet and buying new ones. So, i replaced the O rings and ones fixed the other is leaking ten times as bad. So i just wanted to ask is there a easy way to make the connection withe the injector and the fuel rail while the rail is still hooked up? I have the bolts romoved and the fuel connection near the front. Or should i remove the entire rail and all the injectors, and then put it all back together? whats the best way of doing this?
Use the search tool for "Crankshaft Position Sensor install", must be over 100 great threads on how to and how not replace it. Do not search three three letter items, like CPS. The search tool requires 4 letters.
Remove the entire fuel rail (but you can leave the hoses attached), remove all the injectors (clips!!!), replace all the o'rings on the injectors (a little vasoline helps avoid cutting or gouging the o'rings). Also make sure there are no old o'rings lurking in the fuel rail or engine head!!!! Install the injectors (that have new o'rings) back in the fuel rail, install the clips, then install the entire fuel rail back into the head gently, slowly and carefully, put once they are set, be sure to push and seat them. Then install the bolts on the fuel rail.
Then once you find some of the old injectors still leaking at body :huh:
(o'ring at the ends won't help that) :doh: pull the fuel rail off again, and start over, and REPLACE the fuel injectors that are leaking at the body seam, like 5-90 suggested! That is if you have not started a fire and burned it all up already. Me I got lucky, and did it the wrong way, three times before I bought new injectors. I have about 18 leaky injectors hastathat I use as boat anchors now, LOL.
Don't mistake leaking o'rings for leaking bodies on the injectors. Sometimes it is hard to tell the difference. I was able to see the difference on mine by cycling the fuel pump on and off, with out starting the engine!!!!
Also i jsut bought the CPS anyone know of a easy way of getting to it ??? i can barely get my hands on it let alone a tool to remove and install one.
thanks again for helping out a newbie
