sherman08
- Belfair WA
I got a pair of those stick on ventshade style hood scoops a while back, (im sure uve seen them or the like before). I decided to mount them backwards, like a cowl, mainly to look different from all the silverados with them on. evnetually I decided it was tupid not to open them up to get some vent action going so i drilled holes through the "vent area" and used a hole saw to cut up into the scoop through the hood. I found myself very disapointed with the amount of airflow coming out of the vents. I didnt figure they would actually work as a cowl at speed but expected to at least have some hot air coming out when it was sitting. If anyone has any ideas, or knows what other people have done i would love ideas. I was thinking mabe little electric fans under the scoops?
you can kinda see them in this pick, if you need more i can get them i guess.
