lawsoncl
- North Idaho
Just found my AW4 manual, and yes the two identical solenoids are the shift solenoids and the one that's different is the t/c lockup. So yes, it's part number 5016120AA you need. If you pull the pan, the B solenoid is the one by itself towards the rear pointing forward.
The part number changed in 1995, but the earlier versions may fit. I sold a set of solenoids to a guy with a 98 and he said that they bolted up, but the connectors faced the wrong way. I think he trimmed the connector on one a little and it was a stretch to get the wire plugged in.
