I got one quote already from state flags (i think that's their name?) and it was about 700 an axle including spicer gears. Seems a bit steep to me. Anyone know of some cheaper spots? HP30/D44 I want 4.56's
I got mine done in newberg at drivetrain specialties, it was like 8-900 dollars for both axles regeared, lockers installed, and sye installed, I just took them the parts though only had them do labor.
this was 2-3 years ago though, they do good work, but I would call for a price update.
Holbrook in Gladstone just did my 44 and 60 with ARB's for $450 total labor. I provided the gears, lockers, and install kits. I paid close to $600 for the gears and install kits.
Holbrook Specialties115 E Arlington
Gladstone, OR 97027
(503) 655-4747
sixstates seemed a bit steep for me. 700 for spicer gears and labor (for EACH axle) it would come out to 1400bucks!!!!!Way too much for me...maybe i will have to stick with 3.55's a bit longer
theres a 3rd generation trans/axle guy that is a friend of the family...
"Bob Reams" he has done manny O axle upgrades, t-case, and Trans work for us over ther years. located in a small shop in independence. im know he'll be cheper than 1400. indy not to far away from salem. pm me if u need his contact info.
Also, pulling the axles yourself will often times cut down on labor cost.
Parts should run you around $600 (gears, install kits, carriers), and labor at the minimum will be around $300 for two axles. Expect to pay $900+ easy.
I have a guy here in gresham that will install gears if the axle is out of the rig for $130 each. he did mine and I have had no problems. He also does custom axle setups and disc brake conversions. He is my buddys father in law and has 25+ years experience. I would recomend him to anyone that needs axle work!
