Flash
- Evanston Wy
Lincoln said:I can't seem to find the parts book I had, I may have given it back. I did find the builders guide and it has a few specs on the cams.
P4529228 - 240-240-24 duration, .430" lift, 108 centerline
P4529229 - 248-248-32 duration, .440" lift, 108 centerline
P4529230 - 256-256-40 duration, .450" lift, 108 centerline
P4529231 - 260-260-44 duration, .460" lift, 108 centerline
P4529232 - 268-268-52 duration, .480" lift, 108 centerline
Not much, so I'll keep looking for the other book.
Did find this though. Mike Lesle's 4 cylinder (puched to 3000 cc's) was running 230 HP @ 6500 rpms and Walker Evans was pushing 285 HP out of the 4 cylinder (2850 cc's).
In order to plug the numbers into the Dyno you would need the to have int valve open(IVO,IVC,EVO EVC) in degrees as well and lift and duration!
Flash!
