Flash
- Evanston Wy
gone postal said:Quick update -
Replaced oil sender today. 60psi cold!! I drove for about 15miles and did some slow cruising on the beach in 4HI. Temps got up to high 220s (have an overheating issue I have to tackle ). Anyway, at that temp, I'm seeing 20 idle and 35-40 at 1500 RPM cruising. When it gets back to 210 on the highway, I'm seeing 30 / 45-50 respectavly.
I'm really hoping that this is an exhaust leak. I know it's hard to explain noises, but when I passed by a construction area that had diesel powered pumps running I thought to myself that is what my engine kinda sounds like. Chattery. I've had it "diesel" before when I sank it in a water/mud hole, so not like that - that was WAY loud, but afterwards my motor seemed quieter than before I entered the hole. I almost wondered if it was a manifold crack that was sealed w/ mud. Is that even possible? It is original, so it has 16yrs and 167k on it. It sounds like it's coming from the lower end though - not top of motor and it's louder on manifold side than passenger. Previous owner said it was rod bearings and that it'd been making that noise for a lil over 2yrs. I just figured it was and after the brakes went, he said screw it and sold it before it just blew up. Guess I need to order an APN header to find out for sure.
Them are good numbers!
could be a lifter going bad or stuck, but i haven't heard you talk a bought, lack of power so my best guess is a ext leak!
get a long rubber hose and stick one end in you ear(no not jocking:laugh3: ) and then move the other end of the hose around all the ext manifold........if its leaking there, you will find it when you brush upon the bad spot!
start with it above the eng, and see of its on the passenger side or driver side to begin with. then place the one end of the hose under the intake and see what you hear! Try it it works vary well!
Flash.
