scottmcneal
- not here
I have read that the 3-row ones have fitment issues.
Only for you.Don't try it or even ask about it.
I bet it's a thousand times harder to replace a radiator in a jeep than a BMW. Stupid hard to work on American junk.
I've never had those issues.
Some have said 3 row does not fit. Might depend on the year. Might be the brand also (radiatorbarn, CSF, etc)
I have read dozens of radiator threads, and have seen people get stuck for 2 hours on the quick disconnect fitting. Figure out which kind you have, and get the proper tool for it. Others have had fitment issues with the tranny line hose not being exactly in the right place, which will not work with hard steel lines. I have also seen people having to resort to hacksawing the tranny lines and flaring them with some special tool, whatever that means.
Like all jobs, nothing is ever as simple as forum braggarts like to pretend, so do your homework on the fitment of the radiator, and the repair job in general. It sucks to get stuck in the middle of the repair. I would only buy a radiator that someone with the same year has verified will fit, otherwise, stuck with OEM since you know it works.
You replaced that rusty pipe in the front, near the water pump? Did you have to cut it off? Did you replace the pipe, or just use an extended heater core hose ?
Thats my question that "pipe" looks to have deteriorated and leaking on my 2000 4.0. I need to do a overhaul of this area and these heater pipes scare me.
I found the Gates hoses on amazon while looking for high pressure line for the power steering. Looks like all the rubber and hoses that are "original" are starting to go and leak.
Is there a good write up to do all this heater core lines that run from the thermostat housing or things to know?
