Rainman
- Sydney, Australia
I have a RHD 95 xj, the plan at the moment is to go dedicated LPG(propane).
if I do this the pcm is going. as such a voltage regulator for the alternator is going to be required.
I have been researching this from what I have found, 90 amp external voltage regulators are not easy to come by, if someone can recommend one I would be much obliged.
- I have found 60 amp regulators but I fear with lights and winch this will be insufficient.
I'm open to other avenues, more amps would be nice, bosch / delco 3 wire is ok IF it will bolt up.
can the back of the denso alternator be pulled off and a onboard regulator be installed?
I would be very much for a different solution that resulted in a larger capacity alternator installed.
any input welcome.
Regards.
any input welcome.
Regards.
