5-90
- Hammerspace
I've been using MMO periodicially in various vehicles for a number of years - it hasn't caused any trouble.
I've noted that B12 will help for a "deep cleaning," and the ATF Type F suggestion is sound (it's very high-detergent - also makes a good ersatz handl cleaner...) but note that engine seals aren't formulated to deal with that much detergent, that long, in that light of a carrier oil (ATF is based with a 10 viscosity oil - fixed weight.) Even odds on older engines developing leaks at the front main, rear main, &/or valve guide seals as a result (but they're relatively easy fixes, if you know what you're about - and were probably on the way out anyhow.)
MMO is a more "gentle" fix, and about every third or fourth oil change, I'll replace one quart of engine oil with one quart of MMO, and run normally. 87 through 89 XJs, anywhere from 160 to 280Kmiles on the clock. I've only had to pull one head, and that was because the lifters were packed with paraffin from the previous owner using either Pennzoil or Quaker State (probably Pennzoil - I won't use the stuff in a two-stroke lawnmower!) MMO wouldn't have fixed that - the only fix was replacement.
