With your rig pushing 200K, how old, or how many miles on the drums?
Uh, you're not taking the whole axle, just the backing plates and other stuff relating to the brakes...
The more I think about it the more I am convinced that your problem are not a bent axle or break backing plate. Either of them would bind wether or they are hot or cold. Think about it,...a rotating piece of steel would wobble all the time no matter what. I would instead focus my efforts on the break drum, break shoes and/or the break hydralic system like the combination valve not allowing the fluid to return fast enough although I do not know if it is possible.
You also said after a major break job that things settle for a while until some miles are put on the replaced parts. Maybe and just maybe the replacement shoes get sticky after some surface wear.
Let us know what work for you.
How do you think the lines fixed it, heyhar? It seems like a line would make it drag all the time- not once per rev and only when warm.
great mpg, so I doubt I'd have dragging...
I bet it wouldn't take a whole lot of drag to create enough heat to warp a drum, especially a chinese potmetal drum, extra-specially since you said it doesn't do it right away, only after it "warms up."
Robert
zero rust on my car, and great mpg, so I doubt I'd have dragging. Is there anyway I could check that without throwing a bunch of parts at the car? I HATE working with brake fluid.
I was thinking...a backing plate shouldn't make a once-per-rev rub. It has to be a rotating part that's out-of-wack for that to happen. A bent stationary part would create a constant problem.
