Well after finishing my Front Bumper, I needed a rear…
And I’m Almost finished with my Back Bumper… It’s finished enough to use but I still want to finish the sides…
Here it is:
First I tapped out the existing bolts holes from the original bumper. They were metric but I tapped them out to 7/16
The rear bumper is made of 4 x 4 – ¼ inch square tube. With a 15 ton - Pintle Hook bolted with 4 – 1/2 x 5” grade 8 bolts
Underneath, I welded a 3/8 inch plate strips to reinforce the screws from the tow mounts.
This is everything all bolted up. I gained 6 inched of rear clearance since taking off the tow hitch even with the pintle hook… I am thinking about cutting off the bottom of the rear quarter panels, so I don’t know how it will finish off the sides yet…
Here is how everything attaches:
Red Arrow - 4 x 4 – ¼ inch square tube
Purple Arrow – 3 / 8 Plate 3” x 30”
Yellow arrows – Stock bolts from Original tow hitch
Light Blue Arrow – 1 / 2 inch Grade 8 bolt tapped through the 5/8 of bumper
Green Arrow – 7 / 16 x 5 ½” grade 8 Bolt
I think it should be strong enough to tug on... It should rip the back end of my Jeep off before it comes apart...
What do you think?
Ken
Here it is:
What do you think?
Ken
