mudderx
- Spanaway, WA
So Im looking at getting a cheap beater xj and need some advice. Its a 91 with a 93 engine in it. Problem is dude says it needs a timing chain? but it runs drives ok to 45ish? Its a disco d30/d35,non abs, and will have an OME 2.5" lift after the 4.5" lift gets swapped out, so it has potential after some axle swaps. Could the timing chain issue be a noncompatible or bad sensor instead? He said he modified the harness to run the new engine and swapped in his intake manifold, but I havent heard it run yet so I dont know. Im getting the xj as a project regardless but could use some tips on the engine swap part. It comes with a spare block with a recent chain (will just need some gaskets to throw on the good engine?) If thats truely the issue I can swap the good timing chain parts from the 91 to the 93 motor right? Thanks
