bigalpha
Moderator
- Tucson, AZ
1. If you're going to warranty my PS pump next week, don't recommend that I have a PS fluid flush done.
2. If you replaced my coolant 6 months ago due to a faulty thermostat, figure out why my coolant is nasty enough to need replacement.
3. If you find my transmission fluid leaking - find out where from so you can fix it. In addition, don't offer to perform ATX fluid exchange service for ~$200 before you end up replacing the fluid to fix the leak.
4. Also, if you tested my battery 6 months ago and found it had low CCAs; don't tell me the battery is *insert green checkmark here*. Obviously, my battery will not magically get better over time.
