jeepinwi
- Eau Claire, WI
I took the time to check the amount of lift for my Crane cam. It's a Crane 753905 and has been run in my stroker for 17,300 miles. I broke in the engine with Rotella T oil and have run an SL rated oil since then. I've always had a rough idle and had a CEL for a "cylinder 6 misfire". The good news is that none of my lifters were collapsed...all had preload.
Here's how I checked the amount of lift:
I know it's not perfect, but It's a very close measurement. I measured each pushrod with the rocker arm loose and at maximum compression. I found the difference and multiplied by 1.6. The actual amount of lift is slightly lower since the pushrods are closer to the rocker arm pivots. Here's my results from front to back:
INTAKE: 1-.395:
2-.416"
3-..422"
4-.422"
5-.451"
6-.458"
EXHAUST: 1-.414"
2-.418"
3-.467"
4-.472"
5-.428"
6-.483"
The cam had .456/.484" valve lift when new. I was hoping these numbers would help explain my CEL, but I'm more confused now. I expected cylinder 6 to have the most wear. Apparently the cylinder 6 lobes are in the best condition. I guess these numbers just confirm that Crane cams really are pieces of junk . The next cam I'm going to try is an Isky 133125. It has a straight .450" lift, and is very similar in specs to the Mopar P4529230 Cam.
INTAKE: 1-.395:
2-.416"
3-..422"
4-.422"
5-.451"
6-.458"
EXHAUST: 1-.414"
2-.418"
3-.467"
4-.472"
5-.428"
6-.483"
