And make sure the batteries in it are good !!!!!!!
Yes, this is also good, solid advice. And since we're on the topic of welding, another bit of good advice is to make sure you have enough shield gas before the weekend. I discovered at 9:15 AM, a solid 15 minutes after I got started working......that I just ran out of gas :doh:
Got the lower inner welds done on the passenger side
Aaaaaand I'm out of gas as soon as I started the driver side
And NO welding supply houses in my area are even open for a half day on Saturday. So I messed around with a few small jobs that would need to get done eventually without the immediate need of a welder.
Got the track bar mount put back on. It only took a minor amount of work to make it fit again.
On to the t-case skid plate. I can't remember who made these but I helped install one on one of the
giveaway XJ's about 10 years ago. It was a very tight fit over the factory frame rails. After adding the stiffeners on my XJ, it just wasn't going to go at all. I had to cut the mounting ears off so I can widen it just a bit. I'll add a 1" or 1-1/2" strip over the cut and weld it all back together.
And with the extra thickness of the stiffeners I was able to tap the bolt holes instead of relying on the thin sheet metal of the frame. It's not optimal, but it's a lot better than before!
Then I finally started making the frame tie-ins for the cage. They're offset from the plates inside and I'll weld them to the stiffeners, as well as add diagonal kickers to the frame on each plate. Due to the design of the front floor plates, I could only get two bolts to hit the lower plate with the material I have on hand. I'll drill another hole to strengthen it a bit, and possibly drill/tap another hole directly under the tube to have a total of four bolts on that plate. The inner plate does currently have four bolts through the floor (as well as being welded), but I didn't add the extra bolt in that area when I originally installed the cage because it fell right over one of the floor drain plates. I have yet to decide if I'll add a second plate to catch the two rear bolts (hard to see-circled in red) or just add the other bolt(s) to the lower plate. The down tube lands directly between the two bolts that are in the lower plate in the picture. I'm sure that to those that are reading this, my descriptions here are as clear as mud. But hey, it makes sense to me! :dunce:
