so i got a little work done.
got the old spring coil buckets cut off the rear dana 44, and started welding on the coilover mounting tabs.
still kinda new to welding so hopefully they stay on!
also made a housing spreader and got the shims figured out for the eaton elocker. i just want to drill the holes for the brake lines and elocker wiring before i do the final install, so i can clean it out good. then i just got to cut off the old shock mounts, clean the axle up good, and throw some fresh paint on it. cant wait!
i also made some control arm brackets for the front and rear. they're 3x3x12" 3/16" wall tube, cnc milled out, bent, and welded. i made some side plates as well to beef them up some.
i also welded on some heat treated washers to beef it up around the bolt holes. I got a t&t frame stiffener kit on order, which will go on then all this crap gets to go on after!
and in case your wondering, the dana44 is still mounted to the parts jeep. i figured it would be easier to work on that way, especially since the body is cut off all around it for the most part.
