Moving transmission mount location.
Stumpalump
Franktown Co.
I'm redoing my crossmember and want to scoot the trany mount over about 3/8" to give my down pipe more clearance. Any harm in that?
Im wanting to shift the trany mount to the right (passenger side) to move the down pipe away from the drive shaft while I have it apart.
If it is an auto with stock shifter, you may run into trouble since one mount is on the body and the other on the trans..If all you need is 3/8"...I would massage the pipe a bit to gain the clearance.
