Well I was going to nount a tube off the frame just behind the shock about 3 inches out from rail and put a poly bump on the bottom this placement would have the bump meeting the arm as it swings up an inward meeting the arm , but whe flwxed I noticed the lowe arm.only has about 2inches before they hit the bottom of the frame rail where the stock LCA would mount , So I cut up some 2x3 .250 .rectangle tube at an angle to match the gap and welded ut on the arm just behind the upper mount at the lower...these are Claytons Radius arms... This should give me the contact want with poly bumps installed .
Noe the question is there a reason I should not do this ? The only thing I could see happening is nending the arm , but I doubt it ...But like I said I have not seen it in practice .
