Well I'm not looking for a street rig or nothing. I use it for mild offroad use a little mud here and there and the day to day of getting me to my house and back on unmaintained roads no matter the weather or season. I just am never really satisfied...I love the 4.0. Best motor I have ever used for a dd. I just like having a little bit more...
Basic starting point is that an internal combustion engine is essentially just a self-motivated air pump with a lot of leftover power--it pulls air into the pump, mixes it with gas and sets it on fire, and then pushes the spent air out of the pump. All of the power for the pump comes from the combustion process, and the leftover power is then directed to the transmission. Only the leftover power is available, and any power that is consumed elsewhere will not be available.
In a four-stroke engine the process is
1) piston pulled down draws air and fuel into the chamber from the manifold
2) piston pulled up compresses air and fuel
3) spark ignites compressed air and fuel, forcing piston down
4) piston pulled up expunges spent air and gasses
The only part of the cycle that produces power is the explosion, the rest of it consumes power that is made from an explosion in some other cylinder. Thus the two basic strategies available are to either make a better or bigger explosion that produces more power, or reduce waste in the engine itself so that more of the power that already exists can be sent to the transmission.
If you want to make significantly more power then you need a bigger combustion chamber with more fuel and air. There's no replacement for displacement. This is $$$ but it works.
Low-dollar mods will not cause your existing engine to produce significantly more power, and instead all they can do is make it run more efficiently, meaning less waste, so that more of the existing power is available to the transmission. For example a high-flow air intake allows air to be pulled into the combustion chamber with less resistance so less energy is consumed on the dead downstroke, while a high-flow exhaust allows air to be expunged from the combustion chamber with less resistance so less energy is consumed on that upstroke. If both are installed then the air pump will have much less drag and there can be substantially more power available to the transmission but you will only be using the power that is already there. Another big thing to do here is get a more aggressive cam that will hold the valves open longer so that the engine can breath better.
Ignition mods that help to ignite the air/fuel mixture sooner or more fully can help to produce a cleaner/fuller explosion that motivates the piston better. The best you can do here is use good spark plugs, wires and distributor parts to get cleaner and fuller spark to the combustion chamber. Our engines do not have adjustable timing in the traditional sense and you have to monkey with the sensors to advance the spark. Indexing the spark plugs to produce fuller ignition will help sometimes. Higher grade gas can help with the combustion process too. Better oil lubrication will reduce resistance on the moving parts. Etc.
One of the biggest things you can do is get rid of engine accessories. On my engine the biggest jump in responsiveness came when I replaced the mechanical fan with an electric. The mechanical fan is always partially engaged, and so it is always dragging on the crankshaft and consuming energy that could otherwise be directed to the wheels, while an electrical fan with a temperature switch only produces drag on the alternator when it is needed. Likewise the A/C compressor, power steering pump and water pump can account for significant drag, and switching out old parts can free up some ponies (one of the articles I remember said their biggest gain was from switching out a nasty power steering pump).
There are a lot of good suggestions in the street forum but that should give you some ideas. Just think about how a mod will affect the engine performance and will it allow more power to the wheels or not.
