Hi. I’m pretty new to this forum as you can see. I’ve been reading lots of threads and learning a great deal.
My Jeep is a stock 1989 Cherokee, 4WD.
Thanks, Cruiser54, for creating the excellent thread with your Renix tips. It’s very valuable information you have shared. The explanation of how good ground connections are essential for proper ECU function was especially enlightening for me.
I’ve put the suggested ground wires in but also have a question. Maybe it’s a stupid question, but here goes….
I replaced both battery cables awhile back because the insulated covering on them was bad. The negative cable was attached to the stud on the firewall side of the dipstick tube along with the other electrical connectors (maybe 2 or 3 of them?) you mention. In contrast, your description in Tip 1 mentions that the negative battery cable is “fastened to the engine block just forward of the dipstick stud”.
Does it matter if my negative battery cable is grounded to the same bolt/stud as the electrical connectors on the firewall side of the dipstick tube? Would it somehow be better if the negative battery cable was connected to the engine block at a different bolt/stud? Or does it all come out the same whether the negative battery cable is grounded at the same bolt on the block or a different bolt on the block from those other connectors?
There are 2 bolts that attach a support bracket for the heater hoses just forward of the dipstick tube. I could easily move the negative battery cable end and attach it at one of those support bracket bolts if it would be better to have it grounded separate from the other electrical connectors.
Here’s a photo of what bolts I have in there:
You can see my negative battery cable coming up from below at the far left and the dipstick tube just to the right of it.
Thanks in advance for your recommendation. Should I move the end of my negative battery cable to a different bolt on the block or is it fine where it is?
