- sacramento
Ive been researching like crazy and trying to figure out everything I should do with a new cam. I don't need one , thing runs fine, just want to do the head gasket for maintenance , and magna flux the head, port it, and figured once I tear it all apart might as well do timing, then once thats apart, might as well do the cam, and so on.
so any advice would be great. folks in the oem tech said post over here...
So I have been searching and I plan to order the Mopar Purple cam with lifters kit p4529229. what else should I be concerned about?
So just to address the cam swap, am I missing anything else- my main concern is valve springs. many guys recommend the P4529215 's, so I was planning on grabbing 12 of them as well. Break in lubes like Z grease or just some Moly grease?
I also plan on having a 3 angle valve job done at local cylinder head shop and use a kit to port and polish the head , mopar performance head gasket P4529242 as well as a melling high volume oil pump 167mvs, new del-pro head bolt kit, in case anyone asks.
I am already running long tube headers and bored TB, ford 19lb injectors.
There are many folks that just do the cam and lifters and call it done but there are many that do valve springs
