Don't know for sure. The guys at transtar insisted on me giving them the model year of the vehicle when I ordered a rebuilt unit, but I strongly suspect they had no idea and wanted to cover their asses.
Another piece of info - 98 and later units have both input and output speed sensors and the output speed sensor is different from the 97 and earlier output speed sensor. A 98 or later AW4 can be installed in a 97 and earlier XJ by swapping the output speed sensor over and leaving the input speed sensor disconnected, but the reverse is not true. There are 4 distinct "sub-models" of the AW4 I know of:
* 98-01: two speed sensors, 23 spline, 0.75:1 OD
* 91-97: one speed sensor, 23 spline, 0.75:1 OD
* 87-90 6cyl: one speed sensor, 21 spline, 0.70:1 OD
* 87-90 4cyl: one speed sensor, 21 spline, 0.70:1 OD, different bellhousing but I *think* it's otherwise like the 6cyl 87-90 one. Torque converter may also be different.
The 97 AW4 has a different electrical connector than the 91-96 but is operationally the same, all you have to do is splice your connector from the old tranny onto the new one and you are good to go.
And yes, the initial post in this thread is pretty inaccurate.
