question:
Are the CTS and IAC from a 93 xj 4.0l HO motor and a 89 mj renix motor interchangable?
working on getting my Mj motor solid. Old rig was a 93 xj and is now the parts rig for whatever swaps.
I have replaced:
cooling system
fuel pump
inline fuel filter
MAP
TPS
O2
CPS
new Vac lines hooked up correctly
cap
rotor
plugs
wires
distributer gear
coil
main power and grounds off of battery
I am fighting horrible MPG and a slight rough idle and slight hesatation when hitting the gas.
I have replaced:
cooling system
fuel pump
inline fuel filter
MAP
TPS
O2
CPS
cap
rotor
plugs
wires
distributer gear
coil
