bigalpha
Moderator
- Tucson, AZ
Will a SWB unit work in a LWB tank? What is the general interchangability with them? Also, are the rubber o-rings (that seals the tank to the unit) the same between XJ/MJ?
Enough of a convincing arguement is they're extremely rare and nothing is compatible with them like xj's. Only part you really need is the sending unit the pump can be interchanged, and only major difference is pump pressure between 4 & 6 cyl and then some differences between the carb'd models as well.
